fuel leaking out
Posted: Wed Jul 30, 2008 1:16 am
by darren nix
i have fuel leaking out of my 32 carb, when you take the bellmouth off and look down the body of the carb , at the base of the body is some holes from which the fuel is leaking out , just above the the float bowl, i have gently given the float bowl a few taps with a rubber mallet to see if it will free up the float in case it,s jamed, but no luck, is there anything to specifically look for when i take the float bowl off, thanks in advance
Posted: Wed Jul 30, 2008 2:15 am
Darrin, when you remove the float bowl, then float, the float needle will also come out. Look at the point..... Does it have a groove going around where it seats ? Probably does, so replace it.
Have a look at yoiur fuel taps too. Disconnect the fuel hoses, turn taps off shake all gas from hoses. Put a paper towl under each hose... Now come back and take another look, do you see fuel residue or any wetness? Your taps might be leaking. Repair or replace.
