900 sq case gearshift oil leak
Anyway of stopping the oil leak from my lh gearshift. I have thought about fitting a seal here but probably would need to do some machining. Any hints accepted with thanks
yes a little seal sits in the cover for your gear shift sharf. I put 2 seals in mine, and a little piece of rubber tubing to press against the seal on the shaft just for good measure.......... No more oil weeps.....
