900SS Turn Signals
Posted: Tue May 06, 2008 2:29 pm
I'm restoring the function of the indicators on my 1979 Bosch ignition 900SS so I can get it through a motor vehicle inspection and would like confirmation of the wiring to them. Do the blue/black and blue wires connect to the signal flasher? There is also an azure/black wire in approximately the same location near the fuse box. Does this connect to the neutral indicator switch? This has been removed on my machine.
Finally, I can't locate the headlamp flasher relay but the handlebar switch does flash the light and I can't find a reference to the relay in the parts book. Was the relay discontinued for 1979?
Thanks in advance for any help with this.
Bruce Martin
Bruce Martin
