How much air in rear Marzocchi shocks for Pantahs
Panta600
Post by Panta600 »
Folks,
could anybody supply information on how much air (max.) is required in Marzocchi rear shockers for a Pantah?
Please advise.
Thanks,
Steve
Nothing beats the 4 x 2 seat of a Pantah!
David Frith
Post by David Frith »
Hi,
I believe marzochhi stradas take 28 lbs. This should be on the sticker around the valve.
Dave
Dave F
MartinMille BANNED
BANNED
Post by MartinMille BANNED »
Dont they have gas in them and not air?
garryc
Post by garryc »
i always used a hand pump otherwise it is easy to put in far too much
Lumpy
Post by Lumpy »
I use a hand pump to pump it up a little too hard. Then check pressure with a digital pressure gauge, then check it again. This will give you the amount of air that escapes when you check it. Add that amount to the 28psi and thats the pressure you should aim for. Theoretically that should bring it to 28psi AFTER you`ve checked it. Works on mine.
