wanted 36mm crank pin and rods
Posted: Sun Oct 21, 2007 5:36 pm
by huit
I am looking for a new crank pin and carrillo rods.
thanks paul
[email protected]
Posted: Mon Oct 29, 2007 7:45 am
by Eldert
Hi Paul
145 or 150 mm c.t.c. ?
20 or 22 mm wristpin ?
Eldert
Posted: Wed Oct 31, 2007 6:36 pm
by huit
Eldert, thanks for your reply!
The little end is 20mm, not sure of pin length.(860gt if that helps)
I will measure and let you know.
paul
Posted: Tue Nov 06, 2007 6:37 pm
by huit
The rod is 150 c to c.
paul
Posted: Sun Nov 18, 2007 11:35 am
by huit
Eldbert,
c to c for the rod is 145,
paul
Posted: Mon Nov 19, 2007 4:35 am
by Eldert
Hi Paul
from the Carrillo Catalog :
the 150 mm rod with a 20 wristpin is called DU750>05906
the 145 mm rod with a 20 mm wristpin is the DU900>05709
Regards Eldert
