Brembo Caliper Change
Posted: Wed Jul 04, 2007 10:21 pm
I have a pair of forks, which have a single caliper mounting spacing of 94 mm's and use 8 mm x 1.25 mm pitch retaining bolts.
I suspect that the Brembo F05 twin piston caliper would have been used but ideally I would like to use a replacement Brembo F08 caliper on the rear of the left hand fork leg. So does that mean I would need to purchase a right hand Brembo F08 caliper?
Is there a conversion kit to fit a F08 caliper to the F05 mounting spacing?
And
What's the minimum and maximum diameter of disc that can be used with the F08 caliper?
And
What's the minimum and maximum thickness of disc that the F08 Brembo calipers will accept?
And
And
