Pre Load End Float
Posted: Wed Apr 25, 2007 4:46 am
by jonduc74
End Float
I understand that you have to “pre load” a GT750 motor by some thou to bring it in to zero end float when assembled, not sure what is the best amount, could someone help out there.
Also does anyone know if it is possible to remove “end float” from the crank by shimming between the casing and the flywheel, without have to split the cases?
Many Thanks John
Re: End-Float
Posted: Thu Apr 26, 2007 2:57 am
by jonduc74
Hi I have also posted this on “Motor & Transmission Shop” Please also look here to view replies,
Jonduc74
