Page 3 of 3
Posted: Thu Nov 20, 2008 1:10 am
by MartinMille BANNED
Steve if you got a screw that is hard to get off and is stuffed beond it!!!
try this , I wouldnt use a impact driver the alloy is not that thick
I had one of those on the other bike no driver would fit any further so out with the heavy gear , disconnect the battery cover as much as you can of the engine get the old masking tape out and several layer later right around the screw you now get the Mig out and mig a 6mm nut through the nut center and onto the screw , you dont need much heat as the screw should now be loose and ready for you to unscrew using a spanner on the nut
good luck with with, its a simple job
Posted: Thu Nov 20, 2008 1:21 am
by nottonight68
geez martin
thats radical-my battery is 40 ft from my bike and i've already disconnected it
i've done that process previously with blind bearings
i think i'll chip away a bit more until i bring out the heavy artillary
torx bit
Posted: Thu Nov 20, 2008 9:33 am
by Lumpy
One way I`ve found useful in removing knackered cap screws is to get a torx bit that is close to the size and tap it in. Takes a bit of finese but the tapping helps loosen of the ofending cap screw.
Posted: Thu Nov 20, 2008 12:02 pm
by Craig in France
Yeh, good tip, that works too.
Unfortunately, these screws are (unless they've been changed over the years), slotted ....
Posted: Thu Nov 20, 2008 11:46 pm
by nottonight68
ok guys ,i live in another part of the world-we have different terminology-whats a torx bit
Posted: Fri Nov 21, 2008 12:31 am
HAHAHA Steve you those little funny shaped star and double star 1/4 drive tools , surely you know them !!!!!!!
Posted: Fri Nov 21, 2008 12:38 am
by nottonight68
i know them not
Posted: Fri Nov 21, 2008 12:46 am
didnt look at Steve's shop if he carries them or not
but plenty for sale in OZ
http://shop.ebay.com.au/?_from=R40&_trk ... Categories
Posted: Fri Nov 21, 2008 12:52 am
by nottonight68
looks like an impact screw driver?
hope you fully checked steve's site for these -or its no soup for you-back to cucciolo
Posted: Fri Nov 21, 2008 1:02 am
You know....I'm not going to loose any sleep over it !!
another Bike site/shop sure but Fleebay get real just trying to help a little and if a little means getting booted so be it
I thought this was a cool site ...and still do......Time will tell wont it ?
Posted: Fri Nov 21, 2008 1:17 am
by nottonight68
im with ya man-i think we all know most other part sources
im sure everyone shops around for best prices etc
when does a forum become a marketing tool? i guess when some one picks up the bill for it-so i can see his point-censorship,in my opinion is a dangerous thing ,open to personal interests.
since joining this forum i have followed numerous links and found a wealth of info-i thought this is what it was all about
cheers steve
Posted: Fri Nov 21, 2008 3:38 pm
by abmartin
Back to the clutch adjuster cover screws, I have had success loosening slotted screws by using a longish strip of steel that is the same width as the screw slot. Place the edge in the slot and use the length as a lever, if you're lucky it will break the bond.
The bodger's method is to use a screwdriver with a square or angled shaft, then try to turn it with an adjustable wrench. Sometimes it works, sometimes it slips and makes a mess.
Posted: Sat Nov 22, 2008 12:17 am
by nottonight68
thanks bruce
i'll give these methods a go
if no success , im thinking drilling
Posted: Sat Nov 22, 2008 10:51 am
by wdietz186
If the screws still have a slot enough to get a good bite with use a hammer and rap the screws firmly and rapidly then use a good fitting screwdriver with a hex bolster or a square shank to fit a wrench or visegrips to provide leverage. Heat from a propane torch will help too. It is the friction from the countersunk head that is making the screw so diffucult to remove. Rapping the screw will break some of the bond that has occured from all the hot/cold cycles. If that fails use a 1/4 in. drill on the screw after you carefully centerpunch the screw.If you have done it right you will have a nice tapered washer on the bit and no damage to the cover. The remains of the threaded part should wind right out. It is an easy[two to three beer] operation.
Posted: Sat Nov 22, 2008 2:50 pm
by nottonight68
thanks guys
i'll try these methods-hope i dont end up looking for new side cover
