I took the SS forks apart ready for paint and overhaul, when I noticed that the rod dampeners where 20mm longer when compared to SD forks
The SS uses a tube length of 580mm while the SD uses 600mm , both fork legs are the same high and both forks when reassembled are also the same high
Here is my question for Steve (US) or Dave
As both forks take roughly the same amount of fluid, would the longer rod of the SS have better dampening as more fluid would have to pass through it at each up or down damping stroke ???
Or is the internal valving different eg; more or less bleed ?
There are also a few differences with the rod valving as well
the SS rod has its scraper ring towards the top and on the later versions this is lower, all they have done is reversed the piston , next to the rod spring on the SS it is more of a cone shape when compared to the other that is now your normal type spring , the SS spring is much heavier and also has one extra washer,the rod length it self is longer on the SS and the lower retaining locking block is steel in the SS and aluminum in the other
The thing that I noticed straight away was the piston, on the SS the piston would expose the top side rod holes this was not the case with the other rod where the piston was inverted thus covering the hole
Here are some comparison pictures
This first picture shows the different rod length , the longer one is and SS rod
Note the relation of holes between each rod and the position of the piston ring
The pic shows the parts that each rod contains note the progressive spring in the SS rod
This last pictures shows the modded rod that I have made using parts from both rods , SD rod with SS spring and base locking block from an SD, has enabled me to use a 600mm SD tube, that I have 4 brand new tubes of anyway by doing so all the rod holes are now lined up allowing be to use 600mm tubes, from the outside both re-assembled fork legs look identical
the top rod is SS rod
the middle is the SD/SS modded rod
the last is std SD rod
I may yet remove my listing on the rod dampeners so that I can do this ,why spend $$$ when I have all the parts for the job , hard chroming my original 580mm tubes @$150 each is the other option modding the rod cost to me is Zero
Comments anyone ???
