Replacement Spoke Kits
If you've dealt with Buchanan's before, what was your overall impression?
Excellent
6
86%
Good
1
14%
Bad
0
No votes
The Worst Ever
0
No votes
Total votes: 7
Guest
Post by Guest »
As a matter of interest, Buchanan's (Azusa, California) carry a range
of spoke replacement kits for almost all vintage Ducati models.
Always remember to post here first before purchasing so other members
can help you get a better price by making a group purchase.
http://www.buchananspokes.com/DUCspokes.htm
Listed on site:
250 - 450 Singles: front and rear spoke kits
V-Twin Disc Brake: front and rear spoke kits
V-Twin Drum Brake: front and rear spoke kits
Who's keen?
[/u][/i][/b]
my experience with Buchanans
I have sent polished rims, along with blasted, polished and painted hubs off to these guys to be built up using their stainless spoke and nipple kit. Each time, the wheels have been built up exactly as I spec'd
NOTE: If you send them just a rim and hub to build up, you MUST also send them a sketch with the proper wheel dish, which means you must measure everything before you take anything apart!!!
cafe*racer
SSD900 Darmah
Post by cafe*racer »
Steve, for all the neophytes, can you please explain 'wheel dish'
wheel offset. For example look at the rear wheel on a 10 speed bicycle..... There is a great offset in the hub, the sprocket side is almost straight out, the opposite side the spokes are at a great angle. OFFSET or DISH. Most front wheels have no dish - the rim is exactly in the center of the hub.
Measure the rim relative to the hub. If it is the same on each side you have no dish or no offset............ If there is a difference, make sure you measure accurately, and make sure your wheel builder understands how much on which side....
cafe*racer
SSD900 Darmah
Thanks Steve, makes sense now, the term dish threw me off track. As a follow up then: What should the offset spec be on my GT with the rear disk conversion using front hub and parts from SS? Jordan
