Does anyone have experience with carb upgrade for a 74 Sport? PHF32 to 36 or 40? Or is it best to leave it alone as original? Presumably, minor porting would be required on the intake in the heads.
Also, can you run them with stacks or better to use K&N for filtration?
Bigger carbs for 750 Sport?
1974 Sport, 1978 LeMans, 1963 BSA, 1970 Daytona
for originality leave em alone unless worn out. THat said, swapping out to 36 is NO BIG DEAL, just hang on to your original 32s for the next caretaker.
I like the spun aluminum MALOSSI trumpets I stock, I run them on my bikes, but the K&Ns are way better as filters....... I take off the top caps and spray off the slides, and wipe the inside of the carbie after each ride on my bikes with the malossi trumpets.....
it depends on how much or little maint you want to do.
duck-a-tye
- Mariana
