I was in the process of taking my MHR to a local classic bike meeting and whilst riding there a I passed a car missed a gear and revved it a bit nothing serious and the bike starting missing and back firing through the carbs. I turned around and headed for home and when I got home I checked the plugs, the compression (1050kpa on both cylinders), the ignition pick ups were tight, swopped the plug caps over, checked the carbs where clean. Everything seems to be ok but the bike does not like to run below 3000rpm and spits flames out the carbs every now and then. The bike was running perfectly yesterday when I rode it. It has a Rita ignition, NGK BHS 7 plugs and had a carb overhaul 6 months ago when rebuilt.
Any ideas to solve.
thanks Trevor
