pantah 750 engine temp?
weldingshop
So I went for a ride, all of 40minutes on a 78degree day; and when I got back I decided to aim a thremometer at the engine.........312-325degrees?
Has anyone else ever took the temprature of the f1 750 engine? Just curious as to normal or not.
weldingshop
weldingshop
weldingshop
Peter is right it's apples and oranges.The 1098 has a layer of water between the combustion chamber and the outer surface of the head. And a much greater surface area to dissipate heat. All the F1 has is the oil that circulates when the engine is running and the fins. I would put the thermometer to use on other things and enjoy the ride.
weldingshop
Lord have mercy;
yes i'm aware of the apples and oranges, and .....
Back to my lame attempt; can some one with a 750f1 or 750 pantah style engine take a 45minute summer time cruse not to exceed the speed limit and for the love of god please find the temp of the engine........just because. Or, i'm just damn curious.
And yes I will just ride it....[/code]
- carl750f1
I did the temperature test for you last week end.
The outside temperature was 74'F,I did a 40 min. ride and I took the temp. on the fins head near the spark plug.
The lower head temperature :300'F
The upper head temperature :282'F
I have a 750 F1 with Big Bore kit, Martin Brickwood Heads and Keihin carburetors.
weldingshop
