Hi folks,
I'm new here so please be gentle.
I would like to obtain Ducati Pantah chassis torque settings (Nm)?
Where does one find this information?
Steve
Chassis Torque Settings
Panta600
Nothing beats the 4 x 2 seat of a Pantah!
Pantah torque settings
Hi Steve,
From the workshop manual, normally.
500 SL version on Steve's site; CD versions on eBay, also paper versions sometimes; or from Motomanuali etc ...
Craig in UK/France
Craig in UK/France
Panta600
Thanks Craig,
I've searched everywhere though I still can't find it?
Specifically, I require the torque settings for the front end. Triple clamps, front wheel axle pinch bolt, front wheel nut, front brake caliper bolts...et el.
I might have to use a generic bolt/nut size specific chart which might suffice?
Steve
Steve
Torque values
Hi Steve,
Ok, got you.
I think you'll find that you can simply use standard torque ranges for 8.8 metric bolts. (Just check if any are fine thread as this can change things).
It's true that Ducati weren't generally very good at specifying values for these locations. I also have a Laverda, and Laverda were much better at giving torque values. And, guess what? They're all exactly what you'd expect ...
Btw, I once had cause to check what the correct torque for the bolts that keep the brake caliper halves together. After a bit of a rummage, the UK Brembo importer came back and gave me ... yup, you guessed, exactly what you'd expect!
Ciao,
Craig in UK/France
Ok, got you.
Ciao,
Craig in UK/France
Same problem
Steve,
I had the same problem...Could not find tourque values anywhere. There are vtorque values for the newer bikes at Ducati's home page ...some of these will apply
But yes...most annoying especially when it came to brake calipers, axle nuts, brake rotors etc...
There is a ton of stuff on the net regarding types of bolts and their structural strength/tourque values...could not post them here sorry
When in doubt do this: Keep srewing the bastard till it strips then back it off half a turn!!!!
Think once, think twice....Think soft aluminum cases!!!!
Bumbler.... '82 Pantah 600
Panta600
I ended up using a Suzuki SV650 service manual which has a page of torque values for metric size bolt diameters. It lists torques for conventional bolts (8.8 grade) and high tensile steel bolts (10.5) I think? Anyway, have not stripped threads or broken lugs thus far.
Maybe the top fork brace will fly off when I get this old dunger back on the road!
Steve
