Short answer is : yes
Better Oil Flow to the Sump, And filter ALL of the oil.
Re: Better Oil Flow to the Sump, And filter ALL of the oil.
Ok thx.
This engine also has a dry clutch from a Monster which helps keep the oil clean for longer.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Is that a plug and play swap?
No, not plug and play, but not terrible either. The hardest part was making the inner clutch drive with the right splines.
I really should have made more than one. It all fit nicely in the Brook Henry housing.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
This is the backside.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Ok thank you.
But then, in addition, you change all the system of discs/plates to be "dry" instead of "in oil" and I suppose also that the oil circuit is changed accordingly?
You can install a dry clutch without changing the oil circuit. I just did both at the same time. There is a dry clutch kit here on Bevelheaven.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Dry clutch kit for bevel drive twins with BOSCH ignition are in stock. Link below. I can get same for earlier square case as well as for round case, shoot me an email and I will get you hooked up.
https://store.bevelheaven.com/Clutch-Re ... on-Motors/
