Clutch slip
rightsideup
Clutch slip
Post by rightsideup »
As above, just put new springs in but wide open throttle produces slippage - any suggestions?
'74 Ducati 750GT | '78 MZ TS250/1 | '97 Honda VFR750
In the high latitudes of Finland, in the parching heat of Africa, under the most different operating conditions these motor-cycles run to the satisfaction of their owners.
Re: Clutch slip
friction disks could be worn out. Or did you go to synthetic oil then back to dino oil? That will also ruin friction disks..
rightsideup
Re: Clutch slip
Always dinosaurs, I've had the bike 36 years but I might have a look at the plates.
Re: Clutch slip
i have clutch kits in stock
https://store.bevelheaven.com/Engine-Re ... eveldrive/
friction and steel plate kit
or just the friction disks
rightsideup
Re: Clutch slip
Great but sadly UK customs will add at least 20% to that, have you considered a European outlet based in my garage??
Re: Clutch slip
I ship to the UK all the time.
rightsideup
Re: Clutch slip
I know you do Steve, I've bought parts from you before. It's just annoying how UK (probably all) customs gouge you for money for nothing!
