Millennium Technologies in Plymouth Wisconsin does a proprietary Nickel Silicon Carbide (NSC) cylinder plating.
Should last a looong time.
https://www.millennium-tech.net/index.php
$255.00 per cylinder
wdietz186 wrote: Wed Feb 06, 2019 6:15 pm I don't know if there is any advantage to plating an iron sleeve, all of the plated cylinders I've ever seen have been aluminum. I don't think heat transfer would be improved as the sleeve is still shrunk into the cylinder barrel. The bore would certainly last longer but I don't think anyone uses their bevel hard enough for bore wear to be an issue.
