Hi all, my love for the Bologna blasters started last century and in that time I have owned two bevels (S2 which became an Alchemy) a 750 Paso, a 888 and recently a 1977 Darmah I intend to restore. The bike has been modified by a previous owner and appears to run strong. The handle bars and SSD style pegs have made way for original items in a quest to make it more comfortable.
Unfortunately I don't have the correct kick starter (mine is the shorter curved GT type) and toes suffer for it, I will find one one day either that or I cut and weld the one I have. Unfortunately it has no starter motor but the case / housing is there so when I source one that will go in. It is currently painted a red / gold combination in the SSd style which is ok and I can live with for now.
Will probably ask a number of silly questions thanks for the add. I think I added the picture ok.
Darmah down under
Converted Duc
Re: Darmah down under
1977 , Must have a low number then.
Pity about the original wheels and discs but now EBC floaters on the FPS wheels. Nice touch
Starter probably dumped because the starterclutch went bad. Nothing that can't be fixed.
Conti 2-1 ?
Conti 2-1 ?
Welcome aboard
Hi Converted Duc, curious, were foot peg mounts added/welded to the frame to use the SSD set up?
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
