header interchange??
llewdaert
Post by llewdaert »
Will Darmah header pipes fit and work OK on my 1977 GTS resto??
please.
James
Re: header interchange??
Yes. The darmah pipes are dual wall so heavier and ID will be reduced but otherwise will fit
llewdaert
Post by llewdaert »
muchas gracias
bobnorton
Post by bobnorton »
My GTS came with stainless headers and a reciept for Darmah pipes. they do not fit, they have insufficient kick up and foul the rear brake shaft,they also make removing the oil filter difficult. Its very possible that they are NOT Darmah. Just be carefull. They will be cut and welded.
If they are stainless then that are not original pipes so can't be compared to for fitment onto anything....
bobnorton
Post by bobnorton »
Thats exactly what i'm saying, just because someone says they are Darmah does not mean they are.
