Roundcase covers on a Squarecase Engine?
Just wondering if anybody knows for sure if a set of roundcase covers will fit on a squarecase engine?
Re: Roundcase covers on a Squarecase Engine?
Only the primary cover,only pre Bosch ignition.
Thanks, I would have thought it would be the opposite. The clutch side looks like it would fit better.
Thanks for the response!
Yes, the clutch side fits
Primary side is the clutch side. Timing side has all the spinny gears and things that turn the cams.
Just for anybody interested, looks like a guy in Japan ground down a set of squarecase covers to look like a set of roundcase.
http://www.youtube.com/watch?v=USDr-metcdU
http://www.youtube.com/watch?v=EQhOsfHHrfE
He has done much more than grind things down,he has cast new covers and has a buttload of finish work to do on them. Good idea though.
Sammy,
Had a look at the covers, and I'm with Bill. There is some serious finish work to do with those before they would be presentable. I guess some sort of cover is better than none if you don't have one, but surely someone on the planet makes a decent replacement casting ???
There was a guy in OZ who cast some up a few years ago, but it turned out he had used an original cover to make a mould, and not factored the shrinkage in once cast.
The result was, only some of the holes lined up the rest needed to be filed or drilled to fit.
So i'm wondering, does anyone know if they are available anywhere ??
Regards
Rick
Regards
Rick
I don't read Japanese but I think these are the finished cases http://www.youtube.com/watch?v=cO-M9Dr4 ... ure=relmfu
If you need to replace them, they are sold here http://www.oldracingspareparts.com/twin ... 0-ss-1975/
Just be sitting down when you see the price!
G'day Bill,
Just out of interest, how much are they ? cause I found that the worst Ducati sales site I've found ! Maybe too much of the red grape juice over the weekend, but I couldn't find any prices at all ??????
Kind Regards
Rick
Kind Regards
Rick
Hi Rick - Bevel Heaven is a dealer for ORSP so send me an email with any part numbers (ORSP part numbers!) and Monday I will look up pricing for you.
