Crossover Pipes
animosity
Crossover Pipes
Post by animosity »
A question for the guru's out there, my 860GT has had the crossover pipe removed and replaced with a small straight through pipe into the conti's. My question is, will it run better with this set-up or would I be better off fitting a crossover pipe? Will it matter either way?? I assume the crossover pipe is there for a reason...
Thanks!
Harvey.
Re: Crossover Pipes
Post by Harvey. »
The crossover pipe is included to reduce the sound level, letting each cylinder to use both mufflers to reduce the sound. Removing the 'balance' pipe has the cylinders running, with a tuned length pipe, that will allow the sound waves to work to scavenge the cylinders. This needs the carb to be rejetted, especially the front cylinder, or you can lose a piston. :shock:
I would replace the crossover to reduce the sound and preserve the standard jetting.
Harvey.
'Tell it, like it is.'
animosity
Re: Crossover Pipes
Post by animosity »
Thanks Harvey. I'm looking into getting a new crossover and will see how she goes once i get it on.
Cheers mate.
Re: Crossover Pipes
Post by machten »
....Or install one of these Verlicchi's and never talk to your neighbours again!!!!
Just joking. :twisted:
abmartin
Re: Crossover Pipes
Post by abmartin »
machten wrote:....Or install one of these Verlicchi's and never talk to your neighbours again!!!!
Just joking.
I had a Verlicchi 2-into-1 fitted to my 900SS. My wife claimed she could hear me six kilometres away coming up the river valley. Mine is a little different though. The headers and exaust can are separate parts. It is stamped 'riservato competizione'.
Re: Crossover Pipes
I've got a Conti 2-1 on my Darmah and it is pretty civilized. I can't recall ever seeing another one though,must be kinda rare.
Vince
750 Sport [BEVEL]
Re: Crossover Pipes
Post by Vince »
A mate had a Geninaly {sp} 2 into 1,it was painfully loud,
