I have just had a starter sprag clutch in my Darmah fail. I have pulled the engine down and there is brinelling on the races that the starter engages on.
In Australia I have seen a new starter gear that utilises a sprag bearing from a 916.
Has anybody got any experinece with this mod?? Are the bearings stronger, cheaper, more reliable etc etc and is this modification worth pursuing.
I could fit a new darmah bearing but these do seem to a bit of an achilles heel.
I want to build a reliable engine and this struck me as one way to do that.
Your thoughts welcome.
Darmah Sprag Clutch VS 916 or similar
Elliot
Owner of two 78 Dramahs as I can't afford a 900SS or a Greenframe!
stick to the original type sprag and keep your bike IN TUNE and it will last.
http://shop.bevelheaven.com/detail.aspx?ID=67
BEVEL DAVE
- Diana
I have had the 916 upgrade kit sitting in my shed for some time and am about to have it fitted.
If you go the path of the upgrade shop around for the sprag and circlip
Sprag # 70140011A
and circlip #88240011A
prices vary from about $80 USD to $260AUD for the bearing
Sprag # 70140011A
