I am going to have the kickstarter assembly on my Darmah re-chromed, but I am having a hard time taking it apart. I want to get the small rotating arm off of the long arm. Is there a snap ring underneath the chrome cap on top? Or is it just a retaining ring in a groove and you have to compress the cap to get it out? I really don't want to break anything so I figured I would ask.
Dave
Darmah kickstarter disassembly
I thought Darmahs had a fixed kickstart-lever, just get the M8 out and pull it off.
The (first) SS kicks had a small mark on the top of the bolt, unscrew two turns and then align with the axle. Then slide it off.
Can't remember if it had to be pointing towards engine or not.
Have fun
Have fun
Jon Pegler
- Mariana
Some of the Ducati kickstart levers do have a small snap ring fitted, quite deep down inside the top retaining ring..
You do have to push the top retainer down whilst trying to extract the wire snap ring itself, as you suggest.
I've done it myself and know it can be very fiddly to get apart.
I found it fairly easy to re-assemble, though.
Good luck.
Jon
Good luck.
Jon
