Brake Switch
Brake Switch
73 Sport rear brake switch, whats the go mine is on all the time. Can they be fixed, thanks Gum
easy enough to figure out if you just always have pressure in the system... Crack a bleed screw with the key on, did the light go out?
If you are talking about the rear brake the switch needs to be cleaned.
