F1 steering damper?
weldingshop
F1 steering damper?
Post by weldingshop »
My steering damper seems to have quit. real sloppy. Has anyone ever rebuilt one? or i'm I buying one?
Gomi
Post by Gomi »
my advice is to get rid (or keep on the shelves) the original one and buy an Ohlins or something like that.
Original steering dampers on F1 had a bad track record as long as the legend is that they litteraly block. Never had such an issue, but we never know what the real truth is...
carl750f1
750 F1 steering damper
Post by carl750f1 »
Hi
I have one removed from my 1986 750F1, I removed it in 90 or 91 and it
was working fine. If you realy need it I my be able to do something for you
( I have to find in my garage !! )
Carl
748girl
Post by 748girl »
Hi this is my first post to this forum, apart from introducing myself. As I said in my introduction there will be silly questions, so here goes.
My steering damper has quit, quite literally, in fact it is absent along with the fork clamp :shock: - I think I would like to have one. So, recommendations would be helpful, I was hoping to do an original restoration, but finding one when I don't know what I am looking for is rather difficult. Was it a Bitubo. But where to find one??
If I cannot find an original - what alternatives are there and just saying Ohlins is not going to help me, because I don't know which Ohlins I should have. ie length. I believe the clamp that goes around the forks should be 40mm? is that correct?? I am muddled so....
If anyone can help or suggest something that would be wonderful!
:-D
ducatibruce
Post by ducatibruce »
Hi & welcome to the forum.
I got an original for my 85 from Gowanlochs a year or so ago - so they'd be worth a try.
1981 900 MHR, 1985 750F1, 1989 851 (all from new)
1973 Alfa GTV 2000 (since 1977)
Apparently I had a 4 year Italian itch for a while.
748girl
Post by 748girl »
ducatibruce wrote:Hi & welcome to the forum.
Hi ducatibruce, thanks so much for your suggestion. I have rung them, the man I spoke to unfortunately was far from helpful and in short said he didn't have one, which was a shame because we have lots of things from Gowanlochs over the years. I was hoping that they would have been able to help me with the restoration of the F1. Maybe I will get my husband to ring them, he might get a different reaction to the question "do you have a steering damper for a 1987 F1?"
Thanks again
DesmoKid
Post by DesmoKid »
Dealing with Gowanlochs in Belmore may be hit or miss. Try instead to deal with the man himself as he is more than helpful. And he he has A LOT of F1 parts as well as those old and funny bevel thingies. He can be found via ebay as Italspares. Well worth a try!
Are you talkin' to me?
748girl
Post by 748girl »
DesmoKid wrote:Dealing with Gowanlochs in Belmore may be hit or miss. Try instead to deal with the man himself as he is more than helpful. And he he has A LOT of F1 parts as well as those old and funny bevel thingies. He can be found via ebay as Italspares. Well worth a try!
Thanks Desmokid, in the past Ian has been wonderful. So I sent a message through ebay to Italspares on 8 January - no reply as yet :( Maybe he is on holidays?
I have dampers that will do the job - they are black and adjustable http://shop.bevelheaven.com search for darmah dampers to see them in the chassis section
748girl
Post by 748girl »
@ Steve, thank you - will bear it in mind. The F1 is still awaiting its turn, it is patient and so am I. Thanks again.
