860gt ignition
JD
860gt ignition
Post by JD »
Not sure if this is a premature strike on a problem my bike doesnt have, but I was wondering what other folks do when the stock ignition fails on an early (1975) 860gt?? I know they have been known to. My bike has 32k and some change on the clock and runs quite well--is there an aftermarket alternative? Thanks in advance.
JD
1969 Norton Commando S
1972 Norton Combat Commando
1958 Bianchi Tonale
1959 Gilera 150 Sport
1948 Indian Scout
1977 Ducati 900 GTS
1978 Honda XL250s
MartinMille BANNED
BANNED
Post by MartinMille BANNED »
Hi JD
I'm about to start a 76 SS restoration, when I first got the bike this was on my hot to do list as I wanted an ignition system that I could rely on, out with the old in with the new, I know that there was a conversion kit available in the early 80's for them and started to hunt around for one , I ended up finding on Fleebay of all places AU$350 later and it was mine , this was for the base plate and rotor only the pick -ups are from a 94 Monster as are the coils. The end result will be a much nicer power curve compared to the old Ducati Electronica
Good luck finding another kit like it
You can also go for the old Lucas Rita kit again if you can find them that is
I have been told that someone here in Australia overhauls and Modd's them but I dont know knew that is
There are also kits like Moto Witt ignition DMC/2 , Steve used to stock them but doesn't anymore , there a few other kits out there if you care to google and spend some time finding them ,
I spent ages looking for what I wanted good Luck Mate
Marty
Lumpy
860 ignish
Post by Lumpy »
Silent hectik are another but are fairly expensive. The DMC appears probably the best value for money. They were about $750 Canadian dollars a while back. You can also have the old ignish generators rebuilt. This is a cheaper option and they seem to be more reliable after that but your still stuck with that single step spark advance.
It`s worth checking your engine stop relay is not the culprit first. The failure of these causes symptoms not unlike failed stator ie: running on one pot below 3000 RPM. It`s in your head light, just disconnect and start her up. You have to stall her to stop as she`ll just keep running after you shut her off.
If the system is working, Play it safe and run your plug gaps at about .020" to reduce the voltage required to produce a spark.But the real solution is to replace it with something more reliable.
JD
Post by JD »
I did some more searching and came up with another system not mentioned. As I become more obsessed with this bike, I am looking for ways to retain stock appearance but have much more reliable performance. The bike runs great, as I said, but when and where "it" happens is always in the back of my mind. Anyone have reviews or comments on this set up? The details of installation seem very straight forward- though it doesnt have the advance curve silent hektic does, or DMS for that matter. I like the simplicity and the price. Thanks again-
JD
elektronik-sachse.de/phpshop25/shop/
1958 Bianchi Tonale
1948 Indian Scout
1977 Ducati 900 GTS
1978 Honda XL250s
JD wrote: <snip> Anyone have reviews or comments on this set up?
Don't know about Ducrappis, JD, but Volker Sachse's stuff is generally well thought of by the Laverda mob. For example, go http://laverdapedia.com/forum/index.php?topic=41663.0
MartinMille BANNED
BANNED
Or you could always go for one of these units , they make a stator plate and rotor to suit
http://www.elektronik-sachse.de/ZDG3/du ... 0ss_en.htm
Cheers Marty
Doh didnt see Craig's post :lol: :lol: :lol:
JD
Post by JD »
Marty-
That was the link I was attempting to put on. Appears to be a fool proof kit.
Thanks.
JD
1958 Bianchi Tonale
1948 Indian Scout
1977 Ducati 900 GTS
1978 Honda XL250s
BEVEL DAVE
Post by BEVEL DAVE »
Not too badly priced at the moment either.
They do a starter motor version to, which is handy.
Dave.
davewfc603
860 gt
Post by davewfc603 »
Hi I was wondering how the new system worked out on your bikes, thanks Dave
75 GT860
