Crankshaft preload- how much
Posted: Tue Apr 13, 2010 10:15 am
by Per Garbos
I sat the endfloat to nil and no preload for about 10.000 km ago at my crankshaft, but now there seems to be a little endfloat.
Using a dial indikator I can measure around 0,01-0,02mm.
Is that acceptable or should i do something about it ?
Best regards Per
Posted: Wed Apr 14, 2010 2:43 am
by BEVEL DAVE
They need some preload, more feel than measurement though.
Posted: Wed Apr 14, 2010 11:50 am
by Per Garbos
Thanks, i will give the crankshaft a little preload.
Posted: Wed Apr 14, 2010 3:55 pm
by wdietz186
I try to shoot for about .004" or a slight drag on the crank when turned.It will fall slowly and smoothly when the counterweights are about 90deg. from vertical.As Dave said it is kind of a feel operation.
Posted: Wed Apr 14, 2010 6:16 pm
by machten
That's the ultimate test I use too.
preload
Posted: Fri Apr 16, 2010 4:30 am
by Lumpy
I set one once to what I calculated as zero and after about 15,000 k`s it developed endfloat again. The next one I did I aimed for .002" preload and that has been fine.
Posted: Fri Apr 16, 2010 9:54 am
by Per Garbos
Thanks for the advises,
Then i think i will adjust the preload to 0,03 -0,05 mm and thereafter check that the crankshaft can rotate by its own weight as described.
