Slides and ramps.
Slides and ramps.
My 76 GTs has 70 slides.I'm thinking of fitting 60's, what suffix number should i be looking for? and is there much difference between a /1 and /2.
- Parallel Twin
Re: Slides and ramps.
I strongly suggest you install 60-1 slides,and set your pumps to 5cc per 20 squirts.
Thanks guys, Every part of this bike is a minefield!, lots to learn and lots to do.
I've got some bad news, Bob. Even after 35 years of bevel ownership, nothing changes . Hang in there though, get it sorted and ride it through the twisties, and it does repay you!!!lots to learn and lots to do
I bought the pair of 60/1 slides that were on E-Bay, and am fitting them, no idea if they will improve anything as i have not ridden the bike at all. Whats the best method of checking the pump output?.Have to say i like Ray's" empherical" attitude!, I'm a bit like that myself and get a bit grumpy if i have to explain my decisions!(cave man attitude)
- Parallel Twin
Squirt the fuel into a container 20 times,allowing plenty of time for float bowl refill. 5cc total for twenty full squirts is what you want.
- Parallel Twin
The result will be the delivery of the needed (but very minute) amount of extra fuel at the earliest throttle opening,and you will notice the improvement. Also:you may find your needle setting is now a bit rich,due to component overlap from the richer #60 slide but I am not sure about that. See how it goes!
HI RAy, the 60 slides are for a later carb and need a little machining of the screw ramps to clear the base to drop right down. The diaphrams look sound if a little baggy, can the pump be tested with the carb off the bike?
- Parallel Twin
Have you got a left/right slide mixup,or something like that?The carbs of course must be off the bike to set that pump volume! How else would you catch the gas to measure? I just held them up against a small glass jar,and measured the collected gas with a syringe. Seems to me mine were just about correct already,but that was 35 years ago.
Slides are not handed but are for later carbs and need a little mod to fit, Think i must be stupid, can't see where the pump sprays but managing to get well wet!!, sprays from the brass tube near the bell mouth?, Carb needs working over full range of throttle? Pump piston is set back from slide barrel by a mm or so ,probably needs adjusting, previous owner was a total berk so every thing needs checking.
- Parallel Twin
I would give it one full twist,but it's actually all over after the first little bit of twist. The little plunger/arm,etc.,of course need not to be gummed up,etc. I would wait just a moment between twists.
- Parallel Twin
Whoops.Make that "the little plunger/arm,etc.,needs to be clean,not gummed up,etc."
- Parallel Twin
Here's a good diagram if you enlarge it: http://www.ducatimeccanica.com/dellorto ... o_3_7.html
Thanks Ray, I get the picture!, Having fun replacing the "o" rings and seals, lots of small stuff all very similar but no sizes to work out which is right, not impossible if the old ones are in fair nick,but mine have dissintegrated. I did get the thing running after a fashion ,lots of pops and bangs but happily no Knocks!!.(yet).I can colourtune the idle mixture ok but will borrow mercury guages for the cable sync.Need to get a mate to modify the slides on his lathe.
