I'm finally getting to the reassembly stage but can't figure out where the choke cable splitter box bolts to the frame, if indeed that is the case.
Just for clarity I 'm referring to box that has one cable from the choke lever going in and two cables going out one to each carb. Mine is the square type and has what seems to be two mounting holes on the base.
Thanks in advance
Mick
Choke splitter box location
Re: Choke splitter box location
doesn't bolt to anything. That said on every bevel I have restored I set things up then zip tied it where I wanted it to stay (loosely).
Many thanks that simplifies matters.
You could fit flip up chokes. You won’t be able to use the one on the rear cylinder but the bike should start well enough on the front cylinder only. My bike has a hydraulic clutch so clearing the handlebar of controls is good as I’m not a OEM fanatic
Charles
Charles
