900 Pantah
If you need technical information or help with your Paso based 2 valve non-900 Ducati engine - post your FAQs, comments & questions here.
budgie955
900 Pantah
Post by budgie955 »
Hi all
I've acquired a pantah rolling chassis with a 900 monster engine loosely fitted.
Long term project, so I'd be pleased to hear from anyone who has done the conversion, any info and advice gratefully received.
Dave B
Sheffield UK
Re: 900 Pantah
Sounds like it's going to be a fun project with all the power in that 900..... Once you get things ironed out. What calipers do you have up front on that Pantah? F05 or F08? You may need to upgrade those brakes either way. Let me know what you have and I will help you out with doable options.
Re: 900 Pantah
You should reinforce the engine mounts (especially the rhs front)It's there where the early Pantah cases cracked under stress of the (then) 750 conversions. Take a llo at the "NCR" type frame, that should give You an idea how to do it.
regards,
Return to “'Reverse Head' Pantah Engines [rear exhaust faces rearward] > Indiana, Elefant, Paso 350/750, 750 Sport & SS, Monster 600/750”
