more Paso problems
ordinaryguy
more Paso problems
Post by ordinaryguy »
Well. I think I have the clutch. solenoid, rear brake sorted out. The battery is a bit weak so I went to jump it with the car bat and now nothing works. No lights, horn,starter, brake light,radio? the fuses under the seat are O.K. at first I thought it was The ignition checks out too. I'm getting current just to the parking tail light. Need a check list to start out on. I do get some very intermittent power when I move the left handlebar switches or wire.
jaffa
Re: more Paso problems
Post by jaffa »
Thats doesnt sound too good, I would put my money on a fuse, lets hope you havent fried your computer, which can happen if you connect your cables incorrectly.
I would put my question to the Paso website though, there are a lot of guys there that will help with this question.
http://ducatipaso.org/
If you arent a member, cost is free so good value for money and the forum is a wealth of knowledge.
Good luck.
Jaffa
Volvo Aware Motorcyclist
'78 Darmah
'92 907ie
'82 900 MHR
