Alazzurra 650 oil filters
mustangdan
What filters will fit my alazzurra 650? Thanks!
Life is like baseball, 3 strikes and you are out!
Gary Patton
K & N filter #KN-153 is the best I know of and it comes with a nut on the bottom drilled for saftey wire.
Gary
So Cal
Gary
So Cal
Luca Guala
Filters for Alazzurra
the Alazzurra will accept the same filters as used by all other two valve Ducatis (and I guess also 4 valvers use the same oil filter). I agree about K&N being the best, but they are also the most expensive.
In Europe, at car parts shops you can find very cheap filters that will fit all Ducatis: they are the oil filters for the Citroen 2CV, Dyane 4 and 6, LN. I think also some Simca - Talbot cars used the same filters.
On another note, the cars mentioned above also have a very nice oil cooler, all aluminium, that can easily be fitted to any Pantah-Alazzurra or other Ducati twin
Once I found a suitable oil filter at an industrial machinery shop: it was for a VM diesel engine and it carried the same code as the original Ducati spare! (but also the same price!)
The filter for the big Guzzi twins will fit too, but it's shorter so it may be difficult to fit-remove (on the other hand, probably a filter for a Ducati will fit a Guzzi
Luca Guala - Pantah mixer
oil filters
Filter cross ref:
These will all fit belt-drive Ducatis. Quality varies, do your own research.
Amsoil also makes one which is supposed to be very good, nearly as good as the K&N.
US available: (exact)
K & N KN-153
Perf-Form DUC-1
US available: (near exact, works fine)
Fram PH6074 (was PH2839, PH2864A)
Purolator ML16829C (was FC 103 or OC 5)
AC Delco FX0011 (was X4A)
Motorcraft EFL 47
NAPA: 1352 (1352NAPA and 551352 on the box)
Cooper Z64
Non US:
Champion H101
Powertrain FL125
Fiaam FT4654, FT 4847 or PA7059
Purflux LS187
Halfords HOF216
Tecafilter Ref OC5
Technocar R12, R72, R434
Knecht OC 5 (equivalent to Ducati #065149960 and #090549960)
TJ FB2094
Mann & H W712/9, W712/11
Unipart GFE 201
K & N KN-153
Perf-Form DUC-1
Motorcraft EFL 47
Cooper Z64
Non US:
Champion H101
Powertrain FL125
Purflux LS187
Halfords HOF216
Tecafilter Ref OC5
TJ FB2094
Unipart GFE 201
1977 500GTL (restored)
1980 Darmah 900SS (being restored)
1986 Alazzurra 650SS
1986 Alazzurra 650SS (project renov)
1986 Elefant 650 (needs work..)
1995 900SS SP #591
1996 600SS
1998 900SS FE
2005 Monster S2R (on my third tank...)
1995 900SS SP #591
1996 600SS
1998 900SS FE
I NOW STOCK ATHENA OIL FILTERS FOR ALL SCREW ON STYLE DUCATI ENGINES. oops, I will get them loaded up in my cart soon
