First post on bevelheads. I've searched the forums for this topic but couldn't find answers. Apologies if this has already been discussed.
I have a relatively newly acquired '72 450 Desmo Silver Shotgun that I'm currently trying to sort. It has a Ducati Elettrotecnica electronic ignition which I'm told was fitted as standard.
My problem is trying to get the ignition timing right. What I'd like to know is how does the advance work with these systems, and more to the point, how is it supposed to work? I've read posts about the advance increasing with engine speed and this being an inherent property of the magnet/pickup design. However, when I observe timing versus rpm with a timing light I see no change to ignition timing at all, from idle to high rpm.
Currently the spark occurs at close to TDC, which is fine for idle, but when the engine is revved the timing doesn't appear to advance at all.
Needless to say the engine feels a bit sluggish on the road, and I've also noticed to my alarm that the top of the header pipe will glow dull red if the engine is revved for a few minutes. Not good!
What should I expect to see with the timing light? Increasing advance with rpm? How much? Do I have a faulty pickup or transducer unit?
Lex
