Modern high octane fuels like V-Power OK?
Posted: Mon Jul 26, 2010 5:28 am
Anyone know anything about Shell V-power good or bad and its suitability for use in bevels? This line of inquiry started when I read a few articles from vintage car clubs about running unleaded petrol+LRP additives in older engines - they were pretty positive about the V-power+Valvemaster combination so I tried using this myself recently. Bike seems to like it.
Looked at http://www.shell.com.au/home/content/au ... /overview/
but there's not much specific info here.
In another forum hedton said "My friend rode a 350 Ducati with petrol from Shell called V-power. His Duke was wrecked 2 times before hi noticed that the rubber on the valve in the carb had melted. Hope that this hasn't happened to you."
What's the go? Are the cleaning components that are apparently "designed to prevent the build up of inlet valve deposits and to help remove those which may have been left behind by other fuels" of any real benefit?
Is there anything inherently wrong with using a high octane fuel anyway or is it just a waste in an old engine?
Shell also claims that V-Power has "Friction ModificationTechnology (FMT) ... to reduce friction between the cylinder and piston rings, a critical area of the engine where lubrication is difficult to achieve." Can't be a bad thing, can it?
Steve
Steve
