250 cafe custom, #2
Post pictures of your single cylinder Ducati along with a description here.
joe1028
250 cafe custom, #2
Post by joe1028 »
Imagehi, one of the cafe bikes finished up...
joe1028
duc 250
Post by joe1028 »
joe1028
Post by joe1028 »
joe1028
Post by joe1028 »
joe1028
Post by joe1028 »
duc 250 and cb 750 cafe machines finished up last month
TDF
Post by TDF »
I love it, wish mine looked that good. Did you make the tank or buy it somewhere?
TDF
1966 Ducati 350 Sebring
1965 Ducati Bronco 125
1958 MDS Super Dart
2000 Moto Guzzi V11 Sport
2002 MV Agusta F4 750
Plus a whole herd of non-Italian motorcycles.
joe1028
Post by joe1028 »
the tank /tail section is stock from airtech but modified for the narrow case.(slightly)
joe1028
Post by joe1028 »
under lh cover..heat formed abs inner fender,battery strap,cover brackets with rivnuts,clip in fuses and charge light.
joe1028
Post by joe1028 »
adjustable resistor for led tail light(running-brake off position) which was made up with 20 clear 3.3 v 25 ma leds, 110ohm resistors and then soldered onto a circuit board which was wired and mounted under the tail section to the frame.
joe1028
Post by joe1028 »
Image alum mirror with modified s/s attach hardware
joe1028
Post by joe1028 »
engine plates and hand removable oil dip stick with friction tab so cap will not come loose.
joe1028
Post by joe1028 »
operational airscoop and drilled lever.
joe1028
Post by joe1028 »
joe1028
Post by joe1028 »
Image alum pts cover,s/s retention straps.
sweet bike
looks a treat, thanks for sharing the pix. Recommend you coat that tank with CASWELL tank sealer B4 putting gas in there.
Return to “Single Cylinder Photo Gallery”
