darmah brake calipers
Hi All.
just seeing if someone can advise on how to run the calipers on the back of the wheel rather than over the top.
Is it just a matter of running the forks on the opposite side of each other? If so what about the wheel guard....will that just bolt back in place?
thanks in anticipation
thanks Jon... i'm glad i was on the right track.........just another. Would i need to run the speedo cable towards the front of the wheel?
Yes i do have a pic. i just need to figure how to get it on here.
I think this may do it.
http://mydarmah.webs.com/
cafe*racer
- SSD900 Darmah
MartinMille BANNED
- BANNED
Hi Bruce.
yes i'm with you. i really don't want to move the calipers, but i ordered braided lines and the only way to fit the front 2 lines would be to put the calipers on the back. (the lines are way too long for the original setup) i'm covering my bases just in case i have trouble with returning them. Of 5 lines purchased, only 1 line is a correct fit.
cafe*racer
- SSD900 Darmah
yes swap ONLY the fork legs, everything else gets reinstalled exactly as it came off the bike.
FYI SS brake line kits from bevel heaven available to go from the manifold under triple tree to the metal rigid tubes on caliper as per orignal OR from manifold to caliper directly....
Getting rid of the rigid line and going manifold to caliper takes away a possible place for air bubbles to stay. I have both kits obviously along with thw top line that goes from the master cylinder to the manifild.
I didn't mention that I recently developed another kit that gets rid of the manifild and rigid lines - the kit is for bevels with clipons and each line goes directly from the master cylinder to each caliper.
