Do SS tank and side panels fit a Darmah?
Hi all. Can I fit an SS tank, side panels and dual seat unit to a 1979 Darmah SD? (not to make an SS replica but I am toying with the idea of making a special) If the GTS seat unit fits, does anyone out there have one for sale?
the SS tank sits on isolators perched on a bracket, the darmah tank has rubber bumpers attached to the center frame spar. So the answer is NO unless you want to modify your darmah frame by building brackets to mount the SS brackets onto etc. Seat and side panels are totally different as well - expect fabrication for mounting points.
