who keeps putting caramel on my slides? (77 900ss)
Spub
Post by Spub »
It's now been six months on my Norton fiberglass tank with Caswell sealer. Checked the inside of the tank, and the epoxy does not appear to be affected in the least; it remains shiney and intact. No carb gumming/slide sticking. I figure if the stuff was gonna fail, it would have by now. I am considering coating the inside of my 900SS tank even though it is steel, as it does have a few rust blooms, and this would solve address problem...I also recently helped a friend coat the inside of his Norton's fiberglass tank with Caswell. The stuff comes in two cans, and the mixing ratio is 2 to 3 for the resin and hardener. The instructions say the two cans are enough to coat two 5 gallon tanks, however they go on to say that the interior area of two different 5 gallon tanks are not the same, and can vary to a substantial degree, even though the volumes are indentical (i.e. a 2X2X2 tank = 8 cubic inches, a 1X1X8 tank = 8 cubic inches, but interior area of first tank is 24 square inches, and the the second tank is 34 square inches). I found that after mixing up half of the epoxy and applying it, that this was not sufficient to fully coat the inside of a Norton Fastback style tank. I actually mixed up the rest of it and sloshed this around, and while there was some extra that poured out unused, it was clear that using only half of the mixture would have resulted in an insufficient coating on the inside of the tank.
caswel
oh that is great info Stephen, thanks for sharing. I have heard nothing but GOOD things about this stuff, both for fibreglass AND steel tanks.....
