Factory Ignition Switch
cafe*racer
SSD900 Darmah
Post by cafe*racer »
Does anyone know what the factory ignition switch and keys were for the 750 Gt/Sport/SS? Aprilia, CEV, Magneti Marelli, or other? I have an older Aprilia switch and a newer CEV switch and they don't fit into the hole in my frame. Maybe Gum or someone else can take a pic of a verified original and post some pics of switch and keys.
Gum
750 Sport [BEVEL]
Will do
Post by Gum »
Its late at night here, tomorrow I will get some good pics of it for you. Thanks Gum
Gum
750 Sport [BEVEL]
Ign Switch
Post by Gum »
Here is a pic my switch of a 73 Sport. Thanks Gum
cafe*racer
SSD900 Darmah
Thanks Gum, not what I was hoping for...I think your switch has been replaced at some point. Maybe someone else will chime in here.
Gum
750 Sport [BEVEL]
Post by Gum »
Yes please, as if its not original I would also like to know, that way I can fix it. Thanks Gum
cafe*racer
SSD900 Darmah
I should clarify, my issue is with the key not the switch. All the pictures in Falloon's books seem to show metal keys but none are close enough to tell what brand key/switch. But if the key is a replacement chances are the switch is too.
tony
1976 900ss key
Post by tony »
key on my '76 900ss is an Aprilia - metal key with plastic handle.
the key barrel looks very similar to Gum's above - no visible brand on the facing of the barrel
1974 GT
1976 900ss
Gum
750 Sport [BEVEL]
Key
Post by Gum »
Mine is a CEV with F45 on the lock. Thanks Gum
My 75 750 GT came with a metal key I think it was an Aprilla lock assy. My 77 900SS had the rubber covered key as did the replacement switch I got 20yrs. ago. I still have the 750 switch around in my piles of stuff I'll try to find it tomorrow and determine the manufacturer.
Macdesmo
Post by Macdesmo »
Gum
The key on my '75 SS is the same as Tony's however the one you show is similar as fitted to my Lemans and Benelli Sei as is the face of your lock which seems to have the same rubber insert.
Gum
750 Sport [BEVEL]
Insert
Post by Gum »
Yes it has a nice rubber ring in it. Gum
cafe*racer
SSD900 Darmah
I was lucky enough to get this NOS CEV switch some time ago. Looks exactly like the diagram in the parts book, however it will not fit in the hole in my frame ('74 GT).
nottonight68
BLABBERMOUTH
Post by nottonight68 »
hey jordan
you have fallen for the ''nos'' myth--if it was nos for your model it would fit right in---yes
im sick of parts being described as ''nos''-when theyre clearly not-----
new old stock does not mean new parts made to replace parts no longer available.
my take on your switch size--i got a replacement ign sw years ago (1980)
when rewiring-didnt fit dash hole-had to make hole bigger--later replaced switch--correct size----nos may be for guzzi,lav etc=
you either make hole bigger or switch smaller
post some pics of switch and frame hole-we may be able to help
the oz s
Found my old ign. switch.It matches the picture Cafe*Racer posted the key is the same but has Ducati stamped in it.I measured the threaded barrel on the switch and it is 21.84mm in dia. I think I remember trying to fit the switch in the hole in the left side frame hole and it not fitting either.Plus it didn't have enough clearance to the Dellorto carb.On my 75 750 the ign. sw. was located on the left on a bracket hanging off the front fuel tank mount.I suspect the early ones used a smaller shallower switch on the Amal carbed models.
cafe*racer
SSD900 Darmah
dietz, you are right about the size. Would love to see a pic of your key/switch/bracket if you can post.
oz s, will get back with that info.
J.
