Oil leak 67 350 Sebring
I'm getting oil coming out behind the drive sprocket. There doesn't appear to be a seal on this shaft just some threads on the outside of the sprocket that seem to be for directing the oil back into the engine. Any advice? Thanks
Chris Bushell
- Parallel Twin
It's been out of operation for a year +. I bought it and did a cosmetic restoration on it after checking it out mechanically and running it but not long enough for it to show the leak. It has a new oversize piston in good shape and it doesn't seem to have any restriction on the breather. I'll try the silicone on the spline. Thanks
Chris Bushell
- Parallel Twin
you are correct that there is no seal . there should be a sealed bearing
at the outputshaft . a lot of times a zz type bearing is fitted that is with
a metal shield doing the sealing . a 2RS type bearing would be better
it has a rubber shield on both sides .
unfortionally you have to split the crankcase to replace this bearing
would be a good thing to clean the sludgetrap in the crank flywheel and
check if there is no sludge in the bigendpin .
a lot of bigend assemblys died because lack of oil due to plugged oilholes
in the bigendpin
Regards Eldert
in the bigendpin
Regards Eldert
nottonight68
- BLABBERMOUTH
Hi Jads
yes a twin has sludge traps to . Richard Kennedy aka Richo Roundcase
has a very nice site about the restoration of his 750 GT
if you click on this link you see the sludge trap in the lh flywheel
http://people.aapt.net.au/~arkay/ducati/Crankshaft.html
Eldert
Eldert
nottonight68
- BLABBERMOUTH
no i have a personality unlike youEldert wrote:who the hell made you moderator ? i am just answering a question
i am not the one polluting this forum with 4 plus messages a day of witch
90 % is plain a bullshit .
this is a forum for people that love Ducati singles and twins
if you have to much time on hands find a nice BS forum
Eldert
leoleo
