Exaust temperature
Exaust temperature
I have appreciated (with my hand) a great difference of temperature between exhaust gases by the silencers. it is this normal one?
temp
Hi Gonzalo, that is not normal. That means you carbs are not set right, keep adjusting the air screw, and make sure the carbies are syncronized correctly. Double check the float levels on both carbs.........
Yes, I know but I can´t adjust correcty.
I use vaccum gauge (Twinmax). Fits Tommaselli Daytona 2C throttle
I have checked the insulators and exhaust gaskets. O rings are new and screw air mixture & throttle too. Slides, needles, jets.... all are new
Float levels is OK, at 18 mm
Spark plug are vey black = rich mixture, but jeting is original except main jet (125) because I fits K&N filtes ans Conti replica.
¿problems in enricher circuit?
carb woes
That is the last thing to replace for you, and I will be shipping those choke plungers out today for you. If this doesn;t do it then you might have ignition problems.
Have you replaced the pickup wires yet on your Darmah? I know they are bad if they are original still. You need to find some teflon coated wire to do the job.
