Looking for a technique
rjk40
Post by rjk40 »
Hi Gentlemen,
I'm in the process of getting the sheet metal on my 1975 860GT painted. As most of you know, removing the front fender ("mudguard") necessitates squeezing the two fender/mudguard mounting tabs/tangs off of the mounting studs (4 on each side) towards each other enough to clear the studs. While I have been able to do that successfully, I am going to want to be very careful on re-assembly to not scar the new paint on the mounting studs, and that requires a pretty significant squeeze on those tabs/tangs.
If any of you can provide a technique to do this without scratching the new paint, I will be most thankful. Else, I will have to resort to fighting with the studs to get them unscrewed from the "wheel carrier" (as listed in the parts manual), so that I then have the clearance.
Thanks in advance.
Richard :*<:
Re: Looking for a technique
tilt fender and get 1 side in place
now squeeze the other side in and over the studs
You can also use tape to protect the paint of course
rjk40
Post by rjk40 »
Thanks, Steve,
I don't trust myself to not let go of the mudguard while it is under tension when remounting it, so I chose to unscrew the studs using the tried, and occasionally successful, method of using two nuts with an external toothed lockwasher between them, and then replace the studs through the repainted mudguard holes once it is in position.
I sprayed a bit of easing oil (Blaster is my fave) onto the studs, gave them an oblique tap with a hammer, then I used the tried, and occasionally successful, method of removing the studs by threading on two nuts with an external toothed lockwasher between them.
rjk40
Post by rjk40 »
Hi again,
I hit the "submit" button before I was finished with the stud removal post, so here's the rest of the info:
All studs came out with no stubbornness or damage, which is good, because the studs, Ducati part # 0684.37.583, are apparently made of the rare element "unobtainium", as I could not find any online in the usual places
Each stud has a flat end and a rounded end; the flat end goes down into the hole in the "wheel carrier" , and the rounded end protrudes. The difference between the two ends is subtle but noticeable.
Once the mudguard is in place, there will still be JUST enough thread to get two nuts (but no lockwasher) onto the stud to secure them in the wheel carrier.
A smart move. My MHR has bolts from the factory. After painting my front mudguard and giving the paint a long cure time, I waxed the guard but added a lot more on the sides that would be pressed up against the lower fork legs to do my best to prevent the new paint from sticking to the fork legs.
rjk40
Post by rjk40 »
Thanks, 81.
I've been toying with the idea of putting a washer on both sides of the mudguard, to give just a teeny bit of distance between the mudguard sheet metal and the wheel carrier. As of now, I cannot think of a reason not to. Thin washers are readily available, and the smallest gap would likely solve the potential of the paint sticking to the wheel carrier.
andybaggies
Post by andybaggies »
I waxed the guard
I've just had my frame wet painted and the advised method to prevent scratching/sticking was to use red rubber grease, as used for brake caliper maintenance, or nylon washers.
Andy B
rjk40
Post by rjk40 »
My idea of the plastic washers worked very well.
First, I removed all eight studs from the "wheel carrier, using my "double nut" technique, cleaned and lubed the threaded holes.
With the studs out, there was no need to squeeze the fender to clear them. Placing the plastic washers between the fender sheet metal
and the wheel carrier was quite easy whilst re-inserting the studs, didn't even need a third hand; and now there is no contact between
the fender sheet metal and the wheel carrier. The washers I found online were quite thin, thus they do not distort the fender.
And, there was no reason to worry about scratching the new paint.
Sometimes I scare myself with the thought that my 77 year old brain actually still works.
The Old Man near the Sea
