Starter motor won't turn engine over
Tony Mille
Post by Tony Mille »
On my S2 Mille, first it was an intermitant problem but now it happens more often than not......the starter motor spins happily when asked to, but it doesn't engage with the engine. Any advice as to what could be the problem would be much appreciated.
Mille S2
#ZDM1000S2*100080*
Re: Starter motor won't turn engine over
STOP - Don;t try to start your motor again until you fix this....
Your sprag bearing is toast. TIme for a new one, especially before it decides to almost catch, blow itself up and lodge bits everywhere in your motor.................
Tony Mille
Ah yep it all makes sense, will strip it down over the next couple of days. I see you're selling sprag bearings at a very good price at the moment, so will order one plus any other bits i may need (gaskets)in the next couple of days. Thanks for your help Steve
Mille S2
#ZDM1000S2*100080*
no problem Tony. Talk to you later.
Link to my shopping cart website is below in my .sig and with my new software, the SEARCH function is beyond good. Type in SPRAG and you are there. Or look in the ENGINE section. Or look on the index page as there is a photo and link to the sprag bearing..............................
https://store.bevelheaven.com/engine-re ... ring-sale/
Log in to your account (or create one) then add the item(s) to your cart, hit checkout and you will see shipping options with pricing.
We set up a new web store, unable to transfer over 11 thousand customers into database, just click REGISTER and set up a new account... You can use the same user name and password if you want.. Thanks
