SWAPPING FRONT DISCs AND CALIPERs 900ss
calhoon00
Post by calhoon00 »
was wondering if anyone out there has changed the front discs out for latter model floating disc and calipers..more so what model best suited the offset of the discs if anyone has some model thats been done with a few pics would be happy to see them
regards
Calhoon
[email protected]
Would be helpful to know if you have the early 4 bolt disks or the later 6 bolt disks as the offsets are different.
calhoon00
Post by calhoon00 »
it has the original campo rims which are the 4 bolt type.
would change out to 6 bolt later rims if i could find a set ???
thanks
for your 4 bolt disks, we stock stainless EBC rotors
http://shop.bevelheaven.com/detail.aspx?ID=1135
If you want to upgrade your brakes from the Brembo F08 calipers to modern 4 piston Brembo 30/34 we also stock them along with adapters to suit.
adapters http://shop.bevelheaven.com/detail.aspx?ID=925
30/34 goldlines http://shop.bevelheaven.com/detail.aspx?ID=895
GP Billets http://shop.bevelheaven.com/detail.aspx?ID=1399
Of course you have a multitude to master cylinders to choose from as well for the above calipers, I would suggest the 916 or 996 type remote reservoir types
916 http://shop.bevelheaven.com/detail.aspx?ID=785
996 http://shop.bevelheaven.com/detail.aspx?ID=913
and stainless steel brake lines [again we stock several different types], brake fluid [we stock DOT 4 or DOT 5.1 only in your BREMBO systems].
For 6 bolt wheels we have larger 300mm full floating brembo rotors, several kits available in our store, check them out.
mizike77
Post by mizike77 »
Wow, those rotors sure are purdy.....mmmmm.
79 Darmah
78 900 GTS
86 F1B
80 SSD
02 Harley FXD
72 H2 750 triple
08 KTM 300XC
I neglectd to note that the EBC 4 bolt rotors noted above are 280mm of and a direct bolt on situation.
I should also note that I will also have 6 bolt 280mm EBC rotors in the next day or so. EBC sent me 2x left sides and not a pair so they ave shipped me 2x rights now. These are a direct replacement for later bevel darmah, SS, MHR etc with 6 bolt 280mm rotors.
calhoon00
Post by calhoon00 »
question..
so is there a difference between the 4 and 6 hole internal diameters or off set, as was just going to redrill a new set holes..
and the 300mm floating disc, what model are they off, is it the early monsters..
80mm ID for both 4 & 6 bolt rotors
Offsets are different between the two
The Brembo 300mm rotors are off 750F1, 851 etc but have the same offset as the 6 bolt 280mm bevel rotors.
calhoon00
Post by calhoon00 »
will a 320 full floating disc be able to fit with the calliper adaptors..
thanks again..everything is helpful..
No. The adapters work on 280mm and 300mm rotors with the same offset as the bevels had originally.
The newer bikes such as the monster you mention have a much shallower offset (dish) to them as well.
Steve SD
adaptors
Post by Steve SD »
Can you get adaptors for the 65mm calipers to 280mm EBC discs?
Can you get spacers and adaptors for a 320mm disc conversion on a 4 bolt? Surely an adaptor/spacer can be milled to bolt a 6 hole disc to a 4 bolt wheel?
Yes
No
Why bother seeing as we have already come up with an overkill kit already, meaning specifically yes you can invent just about any adapter to put anything together but going 320mm plus a 4 piston caliper times 2 on the front of a bevel will most likely result in bent forks and or a bent frame in my opinion if you go that big.
Steve SD
Post by Steve SD »
BevHevSteve wrote:Yes
No
There does not seem seem to be a listing in your online store for the 65mm adaptors? do you sell them?
They are not posted in my online store yet. The guy that makes to F08 to 40mm mount adapters for me mentioned he finished up some kit for 65mm calipers. He is on my list of people to talk to this week to get more info and possibly order some up.
Steve SD
Post by Steve SD »
BevHevSteve wrote:They are not posted in my online store yet. The guy that makes to F08 to 40mm mount adapters for me mentioned he finished up some kit for 65mm calipers. He is on my list of people to talk to this week to get more info and possibly order some up.
I sent you a pm, I want a pair so let me know how I can place an order for them and other parts, Thanks.
