Backfiring from one cylinder
Merridew
Post by Merridew »
Hi
My 1975 860 GTS is backfiring from the front cylinder particularly when I am throttling off.
And occasionally if at a constant speed. The exhaust as a result is getting very hot including the rear muffler.
It does not seem to be oil as it’s not smoking.
It running with foam air intakes. I have ignitech ignition operating with a lost spark.
Any suggestions?
Chris
Ianhood
Re: Backfiring from one cylinder
Post by Ianhood »
A faulty plug can cause that issue. The other think I would check is to see if the exhaust is sealing properly at the head. The threaded ring can come loose and that will give the symptoms you describe.
Merridew
Post by Merridew »
I already changed the plugs.
But will look at the exhaust thanks.
