Hi Everybody,
THe NGK B6HS has gone obsolete and I would like to know what a good non resistor substitute is. My wires are resistor wires and I don't want both resistor plugs and wires in the circuit... Any suggestions would be appreciated !
cheers,
Kara
B6HS Obsolete --- What is non resistor substitute????
- Mariana
Re: B6HS Obsolete --- What is non resistor substitute????
What bike / ign. system?
I have copper wire plug leads, 5K ohm resistor caps and use BPR6HS plugs on my 750 GT w/ a Dyna-S. Been working fine for years now.
Some electronic ignitions are apparently particular though, like the Tri-Spark for Triumphs where either resistor cap or plug, but not both are recommended. No experience with the systems on later Bevels & what they work best with.
