Greetings,
I have a 88 Paso. I was able to start it bypassing the starter solenoid with a screwdriver. It's been replaced but I guess I have the wiring in the correct place. I've got a few more wires than the original schematic shows.
I do have one large wire from the bat to one side of the solenoid. the command wire to the small connection. BTW I am getting a signal from the starter button. Positive wire to the starter on the other side of the solenoid. Then I have two extra wires. One from the Regulating unit and one from the fuse box. I assume they go to the pos. side of the solenoid but not sure. I may not have the correct battery in the bike and the extra wires will not reach the bat terminal insted.
Let me know if you can help.
Thanks,
Ordinaryguy
Starter solenoid replacement
- BevelHeaven Sponsors - Supporting Vendors Who Support This Place and You
- ↳ Click here to become a supporting vendor and sell your products
