I might have some problems with the starter motor at My S2.
(It can also be the batteri.......)
But is it possible to remove the starter motor without remove the big outer cover first and then avoid drain the oil? It is the old type of starter motor (Darmah)
Best regards Per
Removing startermotor on 900 S2 from 82
- Diana
- Diana
- Diana
i lean the bike to the right side for a bit, then put a piece of wood 1" thick under the left side of the center stand then it is OK to remove the entire clutch cover if you need to, but you don;t just to remove the starter..
