NEEDED! dellorto VHB27A (D) body or similar carburetor
butcher_79
Post by butcher_79 »
Hi, I have a VHB27A (D) attached to a Condor A350
Ducati 350cc eng. And when I went to put a bigger jet in the carb, and unscrewed the floatbowl nut the threads came with it, I'm having a friend helicoil the carb body, I'm hoping that will work. But if it doesn't or even if it does I'd like to have, and need an spare carb.
I need anything VHB27-29A (D) the D meaning right hand adjustment, or any SS1/SSI of the same size.
Peter Mille
Re: NEEDED! dellorto VHB27A (D) body or similar carburetor
Post by Peter Mille »
Bill48S
Post by Bill48S »
Hi Butcher, last time I looked I had a VHB29 off my 450D on the shelf - unfortunately the air slide is firmly stuck in its tube.
If you fancy tussling with it, I'm happy to donate (I went Mikuni when I did the rebuild).
Bill
Return to “Single Cylinder Ducati”
