Does anyone have an experience with a crack in the glass on the dashboard?
How to remove the glass and replace it?
Best regards
Bosse
Crack in Dashboard
Crack in Dashboard
Re: Crack in Dashboard
please post of photo of what you are dealing with. thanks
- Paso 750
Hi,
Do you mean the glass in one of the instruments? If so, then, yes, it can be replaced with no difficulty. The problem is more often the case.
If the old one comes off ok, then it can normally be re-used. If the old one is damaged, new ones are still available.
But fitting them, altho' you can do it by hand, is best done using a proper crimping tool. Specialist instrument repairers have them. Go, for example: http://www.guagerepairs.com/
Thanks for tip!
Hedton
Hedton
Here is the photo your sent me of what you are trying to show.
